Date/Time: Tue, 22 Apr 2025 10:17:24 +0000
different chart windows from different futures at a glance
View Count: 118
[2025-01-17 10:33:40] |
User977854 - Posts: 7 |
Hi everyone, I'm a Sierra chart beginner and I'm just wondering how I can look at different futures (CL, ES etc.) in different chart windows at a glance. If I duplicate the charts and "detach" them and drag them to another screen and then switch to another future on the quote board, then all the "detached" windows also switch to the selected future on the quote board? so the same future is always displayed on all windows? Thank you very much for a short feedback!!
[2025-01-17 16:48:42] |
You have your charts "linked" so the symbol will change to all be the same. This is also how the Quote Board changes the symbool for a chart. Refer to the following: Chart Settings: Linking You need to determine how you want the linking setup for the particular setup you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
