Date/Time: Tue, 22 Apr 2025 10:14:27 +0000
Remove order postion lines from trade dom
View Count: 159
[2025-01-17 05:40:09]
SirFinesse - Posts: 2
Hello, how do I remove order position lines from trade dom . It is very easy to do for the chart but I just want to see my delta studies and price . When I enter a order it blocks my studies .
attachmentIMG_5546.jpeg - Attached On 2025-01-17 05:36:42 UTC - Size: 6.51 MB - 51 views
[2025-01-17 06:14:27]
Sierra_Chart Engineering - Posts: 19305
This is not possible on a Trading DOM. However, there are many options to configure those lines, in Chart >>Chart Settings >> Trading >> Visual.
Date Time Of Last Edit: 2025-01-17 06:14:35
[2025-01-17 15:22:16]
Thank you for response ,
I have one other issue and it’s my main charts and my historical depth study, it is hard to see colors? The colors appear but it’s hard to see them unless I zoom in on that candle specifically. But brightest yellow sometimes shows ? I think it might have to do with overlay bars I used to configure my numbers bar study.
Private File
[2025-01-17 17:10:28]
John - SC Support - Posts: 39395
This is about the settings you are using for the Market Depth Historical Graph. There are too many options for us to go over what you could change, as pretty much everything will have an impact, but make sure you have the Maximums and Minimums set the way you want along with the colors and thresholds. You just need to find the right combination of settings for your particular chart.
