Date/Time: Sat, 19 Apr 2025 15:21:56 +0000
Equities Options Live Data
View Count: 195
[2025-01-16 23:29:16] |
Poblano Trading Capital - Posts: 18 |
Hello SC Team; In order for me to visualize live equity options data is through IQFeed correct? Can I connect to Denali ( equity data ) and IQ Feed at the same time? Can you load historical intraday data from previous expired contracts? How do you find the contract names? The 2 links I found for further information are broken: DTN IQ Feed Data Service: Rules for the Downloading of Historical Minute and Tick Data Broken links: IQ Feed Symbol Guide https://www.iqfeed.net/symbolguide/index.cfm?symbolguide=lookup&displayaction=support§ion=guide&web=iqfeed IQ Feed Symbol Lookup https://www.iqfeed.net/symbolguide/index.cfm?symbolguide=guide&displayaction=support§ion=guide&web=iqfeed Thanks for you feeddback. Regards |
[2025-01-17 15:41:02] |
John - SC Support - Posts: 39362 |
We definitely do not have the options data. The only other possible source besides IQ Feed would be Interactive Brokers, but we do not know if they have what you are looking for. You would need to check with them. Can I connect to Denali ( equity data ) and IQ Feed at the same time?
You should be able to do this. It is not something we can test at the moment, but as long as the IQ Feed symbols for Options are unique to the Options, then this should work. As you would enter the standard ticker to get the primary data and then the Options symbol for IQ Feed to get the Options data. Can you load historical intraday data from previous expired contracts?
There are no contracts for Equities, so we are not sure what you are asking here. For Futures, you can get the historical intraday data from us as long as you are getting the basic data from us. If you are getting base data from IQ Feed, then you will be dependent on them for the historical data. If you are getting your base data from us, then you would get the historical data from us. There is no crossover. How do you find the contract names?
You would need to ask IQ Feed about this. We will look into fixing the links, or removing them, depending on what we can find. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
