Date/Time: Tue, 22 Apr 2025 10:17:25 +0000
re: Prop account issues
View Count: 155
[2025-01-16 21:49:11] |
vmitrader96 - Posts: 17 |
Hi Using Bulenox, have 2 accounts, tried to use the Order Allocation feature to link the accounts but did not work kept getting error messages. Allowed me to enter a position with both, but could not scale in, scale out, exit. Also my S/L did not work price would go straight through it. Had to manually close all on Rithmic. Then turned off the Order Allocation feature and was still unable to scale, exit, etc with the single account. Attached the message log |
![]() Attachment Deleted. |
[2025-01-16 22:22:33] |
Your orders were rejected with the error "Total sell quantity of contract would exceed its limit." You would need to ask your broker or Rithmic about this particular error. It is coming from Rithmic and we do not know what exactly it means (we do not know what limit it is referring to). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
