Date/Time: Tue, 22 Apr 2025 10:23:20 +0000
Rithmic Connexion Apex PropFirm
View Count: 204
[2025-01-16 09:31:08] |
Trader369 - Posts: 2 |
Hello Yesterday, I have downloaded the software version 2732. I noticed my chart and DOM could not display the data from the Rithmic server. So I have downloaded the previous version 2726 which works perfectly. Does it mean there is a problem with the current version and Rithmic connexion is not compatible anymore? Will the problem will be solve and will I be able to download next updates or do I have to lifetime keep the version 2726 and never update the software anymore? Thank you |
[2025-01-16 15:14:26] |
Sierra_Chart Engineering - Posts: 19305 |
Refer to the version notes here about Rithmic: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2728 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-16 15:25:12] |
Thank you but how can I take orders on DOM connected to Rithmic and get data from the sierra chart data feed as my server is set with my Rithmic account information?
[2025-01-16 16:36:21] |
Sierra Chart is specifically setup to allow you to get your data from us and trade with your trading service. This is not a problem. Refer to the following: Denali Exchange Data Feed: Integration with Trading Services The main thing you need to keep in mind is that in order to get the real-time data for the CME Group at the Non-Professional rates, you need to have a live, funded, futures trading account, and Prop Firm accounts do not work for this. Refer to the following: Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
