Date/Time: Tue, 22 Apr 2025 10:29:14 +0000
Spreadsheet replay orders cancelling for no reason
View Count: 201
[2025-01-16 04:02:50] |
User745789 - Posts: 374 |
My working orders are being cancelled at 12 noon during replay. I have an open position and an unattached working order. The open position remains, it is not flattened. I have no formula in cell J27 or J78, which handle cancelling orders. What else could be controlling this? Trade Window tab A is disabled (Flatten and Cancel at Set Time) Date Time Of Last Edit: 2025-01-16 06:46:34
[2025-01-16 15:39:45] |
Check the "Time in Force" for your attached orders, as it sounds like this may be the issue. Refer to the following: Attached Orders: Time In Force For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-17 00:39:54] |
That was the solution. It was set to Day, I changed to GTC and all works as expected. Byt why does Day TIF cancel orders at 12 noon? This is for symbol AAPL using NY time zone for the chart. |
[2025-01-17 07:45:28] |
Sierra_Chart Engineering - Posts: 19305 |
For information about this, refer to: Trade Simulation: Time In Force for Trade Simulation Mode Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
