Date/Time: Tue, 22 Apr 2025 10:23:22 +0000
v2732 Problem w/ Horizontal Grid Lines on Chart DOM
View Count: 336
[2025-01-15 23:09:48] |
User214239 - Posts: 31 |
I just upgraded to version 2732 and the Horizontal Grid Lines on my Chart DOM line up differently than before, and not in a logical way. For example, if I set the Horizontal Grid Line Increment to 5 points, instead of lining up on each multiple of 5, like 5, 10, 15, 20, etc, they line up on the 2.50 prices. So the lines will be on 2.50, 7.50, etc. Similar issue if you change them to something larger. If you use 10 points for example, instead of lining up on 10 ,20, 30, they line up on 15, 25, 35. Or if you use 20 points they line up on 50, 70, 90, 110. And so on and so forth with other amounts. They don't line up where you'd logically expect them to line up. It seems to only be an issue on the Chart DOM though. The rest of my charts don't have the issue. Please let me know if you need anything from me. Thank you.
[2025-01-16 00:05:08] |
We did make a change to the Horizontal Grid Lines to get them to line up better in general. We will have to look into this to see what we need to change to get it corrected.
[2025-01-16 04:34:18] |
User724532 - Posts: 14 |
The same thing with regular charts. 5 points scale increment 5, 10, 15, 20, 25 can change to 5, 15, 25, 35 etc. when 10, 20, 30 would be much better. Thank you. |
[2025-01-16 13:42:57] |
Mine is only an issue on my Chart DOM's. My regular charts all seem to be working fine.
[2025-01-16 21:32:12] |
User322767 - Posts: 1 |
Same with mine, when I upgraded to PreRealease 2732 grid lines were drawn at 05, 15, 25 in the DOM. Resolved the issue by rolling back to version 2730 which gave me grid lines at 00, 10, 20. |
[2025-01-21 21:10:17] |
We have removed the recent changes that caused this issue, so the Horizontal Grid will go back to the way it was working previously. This is in the current release (v 2734) that is now available.
