Date/Time: Fri, 20 Sep 2024 03:47:51 +0000
esignal
View Count: 2376
[2014-09-17 02:59:29] |
madra - Posts: 109 |
Hello, message when I start tws. Esignal cannot start. Esignal config file c:\windows\winros.ini missing.Tech support at IB say that win.ros is your issue What does this mean for using SCharts? Thanks for help charlie |
[2014-09-17 10:02:47] |
This has nothing to do with Sierra Chart.
