Date/Time: Tue, 22 Apr 2025 13:54:16 +0000
Number bars imbalance not showing when bid is zero.
View Count: 158
[2025-01-15 17:38:30]
User666015 - Posts: 66
Hi Guys,
Have a strange problem one please, by numbers bars imbalances are working perfectly unless there is a zero involved - then the imbalance does not get highlighted meaning I can miss stacked imbalances. I have a attached a screen snippet as an example. I've been through every setting in Number Bars and cannot fix it, can you help please?
Many thanks,
Bill
imageNumberBarsZeroImb.png / V - Attached On 2025-01-15 17:37:59 UTC - Size: 6.97 KB - 28 views
[2025-01-15 18:25:14]
John - SC Support - Posts: 39395
Refer to the following setting (also note the setting above it):
Numbers Bars: Enable Bid/Ask Ratios with Zeros as Ones
[2025-01-15 18:34:23]
Absolutely brilliant, hiding in plain sight! Many thanks again John...
