Date/Time: Tue, 22 Apr 2025 13:39:29 +0000
Highest High / Lowest Low
View Count: 120
[2025-01-15 15:24:54] |
User367161 - Posts: 19 |
Is there a possibility, I can't find it in the menu, to have "close" as input, as in highest close in n periods?
[2025-01-15 18:06:23] |
Yes, this can be done with most studies. For instance in the "High/Low for Time Period" study, there are Inputs to define what is used for the High (Input Data High) and the Low (Input Data Low). Set one of these to the Close and you will get the highest (or lowest) close for the period. Refer to the following: High/Low for Time Period: Inputs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
