Date/Time: Tue, 04 Nov 2025 18:18:02 +0000
Is Sierra Chart still Wine compatible?
View Count: 1098
| [2014-09-17 01:14:26] |
| User98214 - Posts: 4 |
I have used this software on linux in the past and would like to again if possible. Thanks!
| [2014-09-17 03:11:12] |
Yes, it is. Make sure you run the version which supports "New Spreadsheets". It can be downloaded from this page: http://www.sierrachart.com/index.php?page=doc/download.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
