Date/Time: Tue, 22 Apr 2025 14:38:20 +0000
Can I do the following using Sierra Chart
View Count: 257
[2025-01-14 23:29:04] |
User261038 - Posts: 1 |
Sorry, many questions I could not find on internet... 1 Adding a second "time frame" for the same instrument, in the same chart. Does not need to be overlapping it could be at sub window of the same chart. I am trying to use ES for this situation. 2 Open a ES option chain. Do I need to get Teton for it? If I get Teton, am I still able to trade ES/MES futures besides options on futures? 3 Is this demo platform the same I would get for the $26 monthly or will it be excluding same of it? 4 overlapping 2 indicators in the same sub window? Or overlapping indicator on top of instrument? 5 Having just 1 line on VWAP. (Only the middle one). Thank you Sincerely. G Date Time Of Last Edit: 2025-01-14 23:29:22
[2025-01-15 16:40:43] |
1 Adding a second "time frame" for the same instrument, in the same chart. Does not need to be overlapping it could be at sub window of the same chart. I am trying to use ES for this situation. There is not a way to do this in the same chart. Each chart is a single time frame. Within the main Sierra Chart window, you can have two charts open and tile them so they are on top of one another (or side by side) and have one chart one time frame and the other a different time frame. 2 Open a ES option chain. Do I need to get Teton for it? If I get Teton, am I still able to trade ES/MES futures besides options on futures?
We do not have a Options Chain. 3 Is this demo platform the same I would get for the $26 monthly or will it be excluding same of it?
The trial gives you the full capabilities of the system. The only package at $26.00 is the "Base Standard" package, in which case you would not have access to the TPO, Numbers Bars, Drawn Volume Profile, and MBO information. Refer to the information on the packages at the following link: Description of Service Packages and Pricing 4 overlapping 2 indicators in the same sub window? Or overlapping indicator on top of instrument?
This can be done. Are you having a particular issue with trying to do this? 5 Having just 1 line on VWAP. (Only the middle one).
You would just need to set the Subgraph "Draw Style" for the lines you do not want to see to "Hidden" or "Ignore". Refer to the following: Chart Studies: Subgraphs Tab >> Draw Style For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-15 21:39:46] |
ForgivingComputers.com - Posts: 1042 |
While this may not be exactly what you want, if the other time frame is longer than the chart you are viewing, you can use the "Study/Price Overlay" study. It can be set to any region. For example: to view the 5 min chart on the 1 min chart, you would see the same bar repeated 5 times before changing. If the other time frame is faster, then it would have to be another chart, as the bars would move at different speeds. |
