Date/Time: Fri, 20 Sep 2024 03:48:57 +0000
time lines
View Count: 954
[2014-09-17 00:47:24] |
navigator - Posts: 25 |
How would I draw the high and the low of a 5 min bar at a certain time of day, every day. Also the midpoint of that bar? I want the lines to go horizontal for the rest of the day.
[2014-09-17 03:12:29] |
For this we recommend using the High/Low of Time Period-Extended study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s246 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-17 03:14:15
