Date/Time: Tue, 22 Apr 2025 14:06:00 +0000
AU! Shanghai Futures Exchange
View Count: 128
[2025-01-14 23:25:55] |
Copernicus - Posts: 2 |
Hi, I want gold futures data from the Shanghai Futures Exchange my broker stage 5 stated that DTN IQFEED or CQG do not have these exchanges. Do you know of a specific data feed that can power that platform with it? Thanks, R |
[2025-01-15 16:17:50] |
The only other vendor we have connectivity with that might have this data is Interactive Brokers. You would need to check with them on this. If you do want to connect to Interactive Brokers, then the instructions are at the following link: Interactive Brokers Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
