Date/Time: Tue, 22 Apr 2025 14:41:14 +0000
Heatmap issue
View Count: 215
[2025-01-14 21:59:37] |
tommaso masiero - Posts: 1 |
hi, after I updated sierrachart the heatmap doesn't work as before, I have the study market depth historical graph with the same settings as a friend of mine and it works well for him but not for me. The screenshot is my heatmap instead the other image is my friend's heatmap |
[2025-01-14 22:01:55] |
We are not seeing a lot of difference in the images. Certainly not anything that points to any particular issue. The Market Depth Historical Graph is a complex study with a lot of Inputs that can change how the data is viewed. Due to this complexity, we can not give specific information on what you should or should not set. It really depends on what you want to see. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
