Date/Time: Tue, 22 Apr 2025 14:20:38 +0000
Adding a second user or account in SC
View Count: 218
[2025-01-14 20:39:36]
User257874 - Posts: 30
Hi support,
Broker= AMP
SC = Package 12 (plus teton)
SC can be use in 3 different computers with this plan. Is this correct?
I have a Subaccount in AMP with its own funding (two funding accounts in total)
Questions:
Is there an additional fee to adding a second account?
Do I need a second SC login ID to access the additional AMP account?
If I use both AMP accounts in SC, is it possible to use two different computers at the same time?
What are my options in having two AMP accounts with SC?
Do I need two different SC login accounts to keep balance/statistics and other info independent for each other?
Can I have one SC login and one user trading with AMP account1, and another user trading with AMP account2 at the same time?
Thanks in advance for your help
Ralph
[2025-01-15 15:42:31]
John - SC Support - Posts: 39395
Yes, you are allowed to run Sierra Chart on up to 3 different computers simultaneously with Package 12 (Integrated Advanced with MBO). But, the exchanges work differently - you can only get a maximum of 2 systems simultaneously, and you have to pay a second set of exchange fees in order to get the data to 2 systems at the same time.
There are no additional fees from Sierra Chart to be able to access a second trading account. If this trading account is setup as a sub-account to your other account, then you should see both accounts show in the "Trading Window" for a single Sierra Chart connection to your trading service with AMP. Refer to the following:
Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM)
If the second trading account is not associated with the main account, then you would just need a second Sierra Chart installation to access that second account. Refer to the following:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
No. Refer to the answer above.
Yes, but if you do use 2 computers, you will need to pay for a second set of exchange fees. Refer to the following:
Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously
See the previous answers.
No.
We expect that each Sierra Chart account is associated with a single individual. Refer to the following:
Sierra Chart Purchase and License Information: Licensing / Number of Systems
[2025-01-15 16:59:01]
Hi John, Thank you very for your answer.
To summarize my understanding:
For each of the two funding accounts I can run individual computers (2 computers) with its own SC software,
on each computer (account1 & account2) i can trade and view its individual balance,
will continue paying for Package 12 plus 13.00 for Denali and only pay an additional 13.00 (Denali) for the second computer.
Additional final question:
Once setup this way (one computer for each account)
Are accounts visible in both computers? if so, one can trade in either account?
thanks again
[2025-01-15 18:22:35]
It depends on how the accounts are setup.
It looks like you are using the Teton Order Routing Service, in which case you would HAVE to have the trading accounts setup such that they are both available through the same connection to your Clearing Firm/Broker. As such, both accounts will be available to all installations that are connected to that Clearing Firm/Brokerage.
[2025-01-15 18:35:10]
Hi John,
Got all my questions answered.
thank you very much.
