Date/Time: Tue, 22 Apr 2025 14:05:59 +0000
Changing Color for extended rectangle
View Count: 169
[2025-01-14 20:15:04]
User422361 - Posts: 1
When I draw my business zones in Market profiles or in the a chart I use the tool , draw extended triangle. I use a colour code for different places in the chart. Where can I change or add colors? Currently these are available but I would like to change some or add ?
attachmentDoc1.docx - Attached On 2025-01-14 20:12:40 UTC - Size: 98.62 KB - 125 views
Private File
[2025-01-15 15:32:54]
John - SC Support - Posts: 39395
Refer to the following:
Chart Drawing Tools: Customizing Colors on the Menu
There is not a way to add additional colors to the menu, you are limited to 8.
