Date/Time: Fri, 14 Mar 2025 12:48:05 +0000
Attach Control Bar to Detached Chart
View Count: 110
[2025-01-14 18:50:35]
User688525 - Posts: 280
Hello Sierra Chart,
Is it possible to attach, or at least apply the buttons of a Control Bar to a detached chart? For example, if I have a detached chart displaying on a second monitor, how can I apply Control Bar buttons to that chart, and not an attached chart?
I have read through the Control Bar documentation (Control Bar) and haven't found an answer.
Thank you
[2025-01-14 19:10:48]
John - SC Support - Posts: 38653
On the "Detached" chart select "Window >> Control Bar >> Control Bar n" to have a control bar attached to that window. By default, it will attach to the top of the chart, but you can right click on the Control Bar and select one of the other placement options.
Selecting items on the Control Bar that is attached to a detached window will only impact that window.
[2025-01-14 19:37:18]
Hi John,
Thanks for this. Works perfectly!
