Date/Time: Fri, 20 Sep 2024 03:57:07 +0000
Number of trades at bid X number of trades at ask
View Count: 888
[2014-09-16 20:57:52] |
Bango - Posts: 76 |
Hello, In order to spot market imbalances it would be interesting to add a "Number of trades at bid X number of trades at ask" option to Number bars study. Thanks in advance. |
[2014-09-17 03:58:50] |
The difficulty with this, is that if we add this, it will increase memory use. Therefore, it will be considered later on. We do not think this is something of much significance compared to Bid Volume and Ask Volume which is going to be more precise. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-17 04:00:56
