Date/Time: Fri, 14 Mar 2025 12:49:23 +0000
Incorrect Chart
View Count: 125
[2025-01-14 18:29:02] |
Dorel - Posts: 6 |
Hello I hope you are well How can I modify the Incorrect Chart to be the same as the Correct Chart? Thank you Best regards, DS |
[2025-01-14 19:07:37] |
John - SC Support - Posts: 38653 |
Looking at the charts individually, we do not see anything particularly wrong with the one you marked as "incorrect". Why do you state that it is incorrect? Are those two charts supposed to be the exact same chart? Is it the same times and bar period? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
