Date/Time: Fri, 14 Mar 2025 12:46:59 +0000
Bracket Orders
View Count: 95
[2025-01-14 16:45:43]
User143450 - Posts: 12
I cant find tips on how to separate the bracket orders from being set as first in first out. I want them completely separate from each other.
[2025-01-14 18:30:18]
John - SC Support - Posts: 38653
Unless you are using "Scale In"/"Scale Out" options, the bracket orders themselves are all separate. It's just the Position that is not separated into individual trades, and this is not something that is going to change in Sierra Chart.
If you want to use a different way to handle the way the orders are filled in the position, then refer to the following:
Chart Settings: Use Last In First Out Fill Matching (Chart >> Chart Settings >> Trading menu)
