Date/Time: Fri, 14 Mar 2025 12:45:27 +0000
Using AMP Futures - Teton (Sierra Chart) with Denali Data Feed as charting simultaneously
View Count: 171
[2025-01-14 15:53:58] |
Oxcap - Posts: 73 |
Hi, I am trading with AMP futures now using Rithmic data with separate SC instance. I want to switch to Teton (Sierra Chart) as my data feed. I currently have Denali Data Feed using CME/NYMEX market depth with my SC account that I use for charting only. If I change my AMP Futures data feed to Teton, would there be any issues? Both are installed on separate SC installations. Thank you in advance. |
[2025-01-14 18:00:21] |
John - SC Support - Posts: 38653 |
We are not understanding your setup and what are on separate installations. Can you please give us more information, in particular, the following: - How many installations do you have of Sierra Chart? - Are these installations on the same computer or on separate computers? - What is "Global Settings >> Data/Trade Service Settings >> Main Settings >> Current Selected Service" set to in each installations? - What is the setting for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" set to in each installation? -- Keep in mind, Teton is an order routing service, not a data service. When using the Teton Order Routing Service, you need to get your data from our Denali Exchange Data Feed. If you are changing the order routing you are using with AMP from Rithmic to Teton, then as long as you are only trading the CME Group, there will not be any issues. The Teton Order Routing Service only works with the CME Group. Let us know what exactly you are wanting to do with your setup with AMP. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-14 19:29:36] |
Oxcap - Posts: 73 |
ok - you answered my question. I am going to change my order routing with AMP from Rithmic to Teton. I am only trading CME products. Thanks |
