Date/Time: Fri, 20 Sep 2024 04:00:59 +0000
DOM issues
View Count: 985
[2014-09-16 18:46:24] |
User80120 - Posts: 6 |
The few issues that I have on the Sierra DOM are. 1) It should not show the P&l on the left side of the buy column, only the amount of contracts.(takes up to much space) 2) When you bought or sold at two different levels and you have the two different profit & stop loss levels, and then you combine those levels to become one, and now you want to drag to a different level, "ONLY" the original entry gets moved and "NOT" the combined! Can this be fixed? 3) Is it possible to have the H&L & VOL spelled out on the DOM? Date Time Of Last Edit: 2014-09-16 18:48:40
[2014-09-16 19:49:17] |
1. Refer to this section for instructions to add, remove, and reorder Chart DOM columns: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns 2. Not sure how you would combine those levels to become one. In any case, sounds like you might be interested in the Scale In feature: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#ScalingIn 3. On the Trade DOM select Window >> Current Quote Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-16 19:49:31
