Date/Time: Fri, 14 Mar 2025 12:48:05 +0000
multiple .cht books
View Count: 122
[2025-01-14 15:49:21] |
User265150 - Posts: 12 |
Hi - a colleague has shared multiple chartbooks, but if i open one, others will close. What I want to do, is create a desktop which combines some information from a few different chartbooks and use this as my master display. How can i do this please?
[2025-01-14 15:54:46] |
can you pls resend reply - i had a message to say that you'd answered but can't see your reply...
[2025-01-14 18:03:20] |
John - SC Support - Posts: 38653 |
There are a few options for what you want to do. 1. If you just want a few windows open from another chartbook, then use the option for "Window >> Window Always Visible" to make the chart stay displayed when viewing a different chartbook. Refer to the following: Window, CB and CW Menus: Window Always Visible (Window) 2. Use the option for "File >> New Instance" to start a separate instance of Sierra Chart and open a separate chartbook in each sub-instance as you want to have multiple chartbooks visible at one time on the monitor(s). Refer to the following: File Menu: New Instance (File) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
