Date/Time: Fri, 14 Mar 2025 12:48:04 +0000
Where to find the ESH5 symbol?
View Count: 177
[2025-01-14 15:44:28]
User582666 - Posts: 1
I have the Denali data feed, package 11, and the CME/CBOT exchanges.
As a Selected Service I have "SC Data - All Services"
I would like to view "esh5". I currently have only "ESH25-CME".
Do I need to select something else as a service?
Thanks.
[2025-01-14 17:49:09]
John - SC Support - Posts: 38653
Every service uses a different symbology for futures contracts. For "SC Data - All Services" the format of the symbol is SSCYY-Exchange, where SS is the Symbol, C is the Contract Month, and YY is the 2 digit year. The Exchange depends on the particular exchange for that product. So ESH25-CME is the correct symbol for the "E-Mini S&P 500 Futures" for the March contract in 2025 which is traded on the CME exchange.
As long as you use the "File >> Find Symbol" to find the symbol you are looking for, you will get the correct format for the current selected service you are connected to.
