Date/Time: Fri, 14 Mar 2025 12:50:29 +0000
ACSIL/Denali/Teton: Two Ticks Negative Slippage on a Closing Limit Order Trading MES?
View Count: 105
[2025-01-14 15:29:14]
ondafringe - Posts: 315
It was a minute after the open, so a fast moving market... but it was a limit order to lock in three points on one contract and it filled for only 2.5 points.
I replayed the trade in SIM using Accurate Back Test at 1x speed and made 3.25 points.
I've never had that issue with a limit order before. What are the mechanics that would cause that to happen?
[2025-01-14 17:45:03]
John - SC Support - Posts: 38653
If this was an order in Simulation Mode, then refer to the following:
Trade Simulation: How Orders are Filled
If this was a live order, then you would need to ask the Exchange about how your order was filled.
[2025-01-14 19:07:58]
I figured out what happened. Thanks.
