Date/Time: Fri, 14 Mar 2025 12:43:54 +0000
Sierra frezzes and nothing happens
View Count: 108
[2025-01-14 15:01:57] |
sahandprs - Posts: 13 |
If I disconnect and reconnect, the chart loads, but it immediately freezes afterward and nothing happens
[2025-01-14 15:40:46] |
Sierra_Chart Engineering - Posts: 18778 |
When you say freezes, is Sierra Chart in a frozen and inoperable state and you cannot interact with it? Or is the chart just not updating? If the chart is not updating, refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-14 15:40:58
[2025-01-14 17:59:39] |
Chart just not updating And weirdly started to working after 40 minutes or something |
[2025-01-14 18:47:36] |
John - SC Support - Posts: 38653 |
Refer to the following if this happens again: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
