Date/Time: Fri, 14 Mar 2025 12:45:27 +0000
Color bar based on alert question
View Count: 114
[2025-01-14 10:33:16] |
User993440 - Posts: 19 |
Hi, Based on the position of the bar POC (using the Volume Point of Control for Bars study) in a range bar, I'd like to color the bar. Please see the attached image to see exactly what I mean. |
[2025-01-14 12:46:52] |
cmet - Posts: 677 |
Can't see your image, no idea what the rules are. Basic example assuming VPOC for Bars is ID:1 SG1 and you're coloring the bar green if it's above the midpoint and red if it's below. Green: ID1.SG1 > (H + L) / 2 Red: ID1.SG1 < (H + L) / 2 For draw style, choose color candlestick body and choose your color. |
[2025-01-14 13:01:29] |
Thanks for the reply, see the attached image for what I'm looking for.
Date Time Of Last Edit: 2025-01-14 13:01:55
[2025-01-14 13:08:57] |
cmet - Posts: 677 |
ID1.SG1 >= H - (2 * TICKSIZE) ID1.SG1 <= L + (2 * TICKSIZE) Definitely worth learning the alert syntax: Study/Chart Alerts And Scanning: Alert Formula Examples |
[2025-01-14 13:38:56] |
Perfect, thanks
