Date/Time: Fri, 14 Mar 2025 12:49:22 +0000
China A50 Futures on SGX Trading Error
View Count: 121
[2025-01-14 02:38:29] |
User624595 - Posts: 236 |
2025-01-13 21:34:20.635 | Trading message from IB: The price does not conform to the minimum price variation for this contract. Error Code: 110. ServiceOrderID: 10640. InternalOrderID: 22613. * 2025-01-13 21:34:20.636 | New order rejected - The price does not conform to the minimum price variation for this contract. Internal Order ID: 22613. Service Order ID: 10640. Symbol: XINA50-202501-SGX-USD-1. Account: * Sell limit order gave this error, but buy limit order was accepted. |
[2025-01-14 05:46:22] |
Sierra_Chart Engineering - Posts: 18778 |
Are these the correct contract specifications?: https://www.sgx.com/derivatives/products/chinaa50?cc=CN#Contract%20Specifications We see the Tick Size is 1. If so we will update the symbol settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-14 05:46:34
[2025-01-14 10:52:35] |
That appears to be the correct contract, see also: https://www.barchart.com/futures/quotes/HNF25/overview https://misc.interactivebrokers.com/cstools/contract_info/v3.10/index.php |
[2025-01-14 15:48:46] |
We have updated the symbol settings for this futures contract. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Follow the instructions here, to apply the settings to the existing chart (very important): Global Symbol Settings: Applying Global Symbol Settings to Existing Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
