Date/Time: Tue, 22 Apr 2025 14:03:01 +0000
import stock trade/tick data into sc
View Count: 178
[2025-01-13 22:32:07] |
User395175 - Posts: 90 |
Hi, i see sc only provide over 180 days of us stock tick data, if i have 10 years of stock trade/tick data, can i import them into sc and make different types of bar charts in sc? if so, how to do it?
[2025-01-14 16:41:16] |
We have more than 180 days of U.S. Stock 1 tick data. It is going to vary for each instrument, but you should be able to get about 2 years of 1 tick data. If you want to import your own data, then refer to the following: Exporting and Importing Intraday Data Files: Import and Load For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-15 13:53:41] |
Do u have any plan to add more tick data in futures? maybe over 5 years? Also, whats the method u used to compute ask and bid volume here?
[2025-01-15 17:31:06] |
No maybe over 5 years?
No whats the method u used to compute ask and bid volume here?
If it is not specifically set by the exchange, then refer to the rules we follow at the following link: https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#BidTrade For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
