Date/Time: Fri, 14 Mar 2025 12:46:58 +0000
Locating Draw Volume profile selection rectangle
View Count: 93
[2025-01-13 21:51:19] |
Chris32 - Posts: 60 |
Hello, I often draw volume profiles on different swings that I display on the right aligned side by side. However, as time goes by, I sometimes forget where exactly I drew them so it can be really tricky to find and select them in order to delete or resize. Clicking the edges of the profile only works if the chart is exactly at the right position. Is there any way that makes it easier to select the profiles? |
[2025-01-14 16:23:57] |
John - SC Support - Posts: 38653 |
Refer to the two settings in this section: Chart Drawing Tools: Volume Profiles (Global Settings >> Tool Settings >> General) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
