Date/Time: Fri, 14 Mar 2025 12:49:23 +0000
Price moving slow on charts
View Count: 114
[2025-01-13 21:38:07] |
AndyJMorris - Posts: 18 |
Hi - not sure what's happended, but the pric is barely moving. My data feed is all fine. I also use Jigsaw and the price ladder is moving as normal. So there seems to be something wrong with SC. Any ideas?
[2025-01-14 07:58:30] |
Why is the Price lagging on SC at present?
[2025-01-14 15:40:01] |
Sierra_Chart Engineering - Posts: 18778 |
What symbol are you referring to? Refer to help topic 4: Prices / Data Falling Behind Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
