Date/Time: Tue, 22 Apr 2025 10:29:17 +0000
Two Questions.
View Count: 203
[2025-01-13 21:04:31]
G369 - Posts: 23
I had two questions.
#1. Why can't I copy the output of a Build/Compile from the Analysis>>Build Custom... >> Output using the keyboard? I have to use the right mouse button to copy it. It would be convenient if you could add this feature.
#2. Have you added Binance back into your data stream? I want to trade Binance Crypto using Sierra Chart. I hope I am not disappointed with this answer, if Yes, what is the reason?
regards
NP
[2025-01-14 15:56:27]
John - SC Support - Posts: 39395
1. It is just the way it is. We can not say why exactly at this point in time. We are changing all the windows to our new format, so that will eventually change to the new format.
2. Binance data is available. Our servers show that you are connected to the "SC Data" service, so if you select "File >> Find Symbol" you will see Binance as an option in the list.
[2025-01-23 01:30:43]
G369 - Posts: 23
Thank you for your reply.
Let me rephrase the question.
Can I connect to Binance live account and trade from Sierra Chart? I can fund Binance today if Sierra Chart allows trading Binance account.
regards
Naga.
[2025-01-23 15:22:49]
We only have data for Binance, we do not have any trading connectivity.
