Date/Time: Fri, 20 Sep 2024 04:06:46 +0000
CQG Data Feed
View Count: 1007
[2014-09-16 17:21:04] |
User66144 - Posts: 4 |
My broker has enabled connections from their side , but still i can get connected to CQG data feed .The message its showing is connecting and waiting to reconnect. I request you to help me in establishing the connection. Thanks |
[2014-09-16 17:34:12] |
Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
