Date/Time: Fri, 14 Mar 2025 12:45:28 +0000
Data not downloading
View Count: 108
[2025-01-13 20:49:16]
Kalyani Wevita - Posts: 1
I installed sierra charts and the screens say "downloading continuous contract data". and it has been like that for several hours and the download doesnt seem to complete. How do I fix it? Attached screen shot.
imageSierra chart issue.png / V - Attached On 2025-01-13 20:48:11 UTC - Size: 14.3 KB - 26 views
[2025-01-14 15:51:41]
John - SC Support - Posts: 38653
Depending on how much data you are requesting, it can take a long time - even several hours. Has this resolved yet?
If you are still having an issue, then please do the following:
- Select "Edit >> Cancel All Downloads" to stop all the downloads for data that are occurring at that time.
- Go to the chart for ESH25-CME and change the Chart Settings for the number of days to load to "5" and select OK to close that window.
- Select "Global Settings >> Data/Trade Service Settings" and select the "Common Settings" tab. Change the entries for the "Maximum Historical Intraday Days to Download" to be the following:
-- Non-Tick Data: 31
-- 1 Tick Data: 31
- Select OK to close the Data/Trade Service Settings window.
- Select "Edit >> Delete All Data and Download" with the "ESH25-CME" chart active.
This will download a smaller amount of data. Make sure you get this in a reasonable time period (not more than 15 minutes). If you are able to get this data without a problem, then you need to consider how much data you were requesting when it is taking a long time.
Be sure to change the settings for "Maximum Historical Intraday Days to Download" back to 186 for each entry.
