Date/Time: Tue, 22 Apr 2025 13:54:15 +0000
Trade ICE Futures U.S.
View Count: 162
[2025-01-13 18:41:40] |
User469228 - Posts: 1 |
I am using sierra chart (Teton Order Routing) to trade. Is there a way I can trade ICE Futures U.S. products? For example, Sugar No. 11 Futures. Thanks!
[2025-01-13 19:10:51] |
You can not do this with the Teton Order Routing Service. Teton is only setup to trade the CME Group. If your broker does offer trading with ICE using CQG for the order routing, then you can do one of the following: - Setup a separate account and use CQG for data and trading ICE. Install a separate Sierra Chart to manage that account. - Change your existing setup to a new account that uses CQG for order routing for both the CME Group and ICE. You would just need to reconfigure your current Sierra Chart to connect to that CQG account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
