Date/Time: Fri, 20 Sep 2024 03:44:43 +0000
Trade Window bug?
View Count: 904
[2014-09-16 17:01:58] |
User57562 - Posts: 98 |
Menu "Trade>Attached Trade Window to Chart" opens TW flush with top of chart. Reopen of menu now shows checkmark. Unchecking item on menu does NOT close TW, but does reopen it with [x] at top right, which permits close. In other words, 3 steps to open & close TW. I don't see option for CTW button to close. That [x] should appear every time. |
TradeMenu1.png / V - Attached On 2014-09-16 16:58:14 UTC - Size: 41.29 KB - 327 views Attachment Deleted. TradeWindow1.png / V - Attached On 2014-09-16 16:58:56 UTC - Size: 29.07 KB - 324 views TradeMenu2.png / V - Attached On 2014-09-16 16:59:10 UTC - Size: 51.24 KB - 302 views TradeWindow2.png / V - Attached On 2014-09-16 16:59:18 UTC - Size: 34.95 KB - 318 views |
[2014-09-16 17:36:31] |
To close the Trade Window when it is attached to the chart, you need to select Menu/M >>Close Trade Window on the Trade Window.
