Date/Time: Tue, 22 Apr 2025 14:26:36 +0000
Teton - Trading is not supported error
View Count: 147
[2025-01-13 14:07:56] |
User725043 - Posts: 42 |
Hi, Got this error this morning on 1 of the connections: Denali Data Feed | Trading is not supported. | 2025-01-13 08:56:23.156 Could you please advise what to do? |
[2025-01-13 14:45:57] |
Update: A trade just got executed on that connection. Unclear why the error message. I have sent the Message Log via the Send For Analysis button. Please find attached the IP addresses I'm connected to. |
[2025-01-13 15:19:31] |
We see the following in your log: DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2025-01-13 08:56:20.467 *
If this is not repeating then it probably just means a temporary connection issue and would not be of any concern. If you are still having a problem, then we need to know what exactly is occurring at this time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-13 18:25:56] |
Sierra_Chart Engineering - Posts: 19305 |
Regarding the message in post #1. This is expected on the data connection and is not of any concern.
