Date/Time: Fri, 14 Mar 2025 12:46:58 +0000
Daily OHLC
View Count: 157
[2025-01-13 09:07:25]
User476926 - Posts: 59
I have a random error that keeps appearing on chart using Daily OHLC study. It is for the SG4 line in the study - set to Prior Close for previous day (does not affect any other line in study). When I open the chart, the Prior Close line starts updating to the current price on the chart and the PC line then moves up and down in line with current price. I have tried changing settings / deleting and adding the study, the only way to get rid of it is to find a chart which does not have this error and completely delete any chart that has the 'constantly updating line'. Has been happening on/off for 3 months, and on different PCs. Can be fine for several days and then just starts randomly (not linked to version updates). Any ideas?
[2025-01-13 17:50:02]
John - SC Support - Posts: 38653
We do not understand the statement: "It is for the SG4 line in the study - set to Prior Close for previous day"
What is set to "Prior Close for previous day" and how is this being done?
[2025-01-13 18:46:30]
In the OHLC study, subgraph SG4 is for "Close" - when I open my chart, instead of showing me the Close as a static line on the chart (in my case it would be set to the previous day's Close or 1 day back, hence I used term "Prior Close") - the chart shows the SG4 line moving up and down in line with the current price on the chart. All the other subgraphs for Open/High/Low (SG1/2/3 etc) are correct and static lines at the value for the previous day. It is just the SG4 / Close line that is not static - it somehow becomes a line constantly updating to the current live price.
[2025-01-13 19:12:47]
How are you setting the study to use the previous day's close? Are you using the option for "Reference Days Back" set to "1"? Or are you doing something else?
[2025-01-14 10:05:32]
Reference day back / Days to calculate both set to 1. It was all working correctly for many months.
[2025-01-14 16:53:47]
Please get us the chart that is showing this issue by following these instructions:
