Date/Time: Tue, 22 Apr 2025 14:29:31 +0000
Candlestick color of Sierra Chart official videos
View Count: 131
[2025-01-12 03:55:36] |
Alex01 - Posts: 17 |
Hello, could you tell me the color code of the green color and also the red color of your candlestick chart in the official Siera Chart youtube video named Siera chart trading please? Link is https://www.youtube.com/watch?v=sIfd4tqKaOY at 5:50. Thank you |
[2025-01-13 17:22:08] |
The general rules for Green versus Red candlesticks are the following: - Green/Up: Close is higher than Open - Red/Down: Close is lower than Open If the Open and Close are the same, then the color of the previous bar is used. The above can be changed to look at the Previous and Current Close values for OHLC bars. Refer to the following: Graphics Settings: Up/Down Coloring for OHLC Bars Based on Previous and Current Close (Global Settings >> Graphics Settings >> Other) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
