Date/Time: Mon, 15 Dec 2025 09:09:45 +0000
[User Discussion] - Global config
View Count: 303
| [2025-01-12 00:34:03] |
| User744218 - Posts: 20 |
Hello, 1) Is there a way to load a study without affecting the chartbook's colors, background, font, or scale? 2) I would greatly appreciate it if someone could kindly share a GLOBAL configuration file with decent settings. Thank you! |
| [2025-01-13 06:19:08] |
| Sierra_Chart Engineering - Posts: 21843 |
1. Yes, this is always inherently the case. The only exception would be a custom study that is changing these graphics properties globally. This would be rare. 2. We will leave this to other users. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
