Date/Time: Tue, 22 Apr 2025 14:11:46 +0000
Emergency Account Activation
View Count: 185
[2025-01-11 22:27:04] |
User104854 - Posts: 457 |
If I'm in the middle of a backtest I typically use this feature when I get notified that my account will expire in 2 hours. It clearly says that if I'm performing critical operations then to activate it. When I go to activate it though, it says the feature is not available because my account is not expired. Why do I have to wait until my account is actually expired to use it? Doesn't this defeat the purpose? It didn't used to be this way. If there are 2 hours left, I should be able to activate it so that it doesn't interfere with my 'critical operations'. Can this be fixed? |
[2025-01-12 23:12:57] |
Sierra_Chart Engineering - Posts: 19305 |
Make sure your computer's clock is set accurately. : Incorrect Date and/or Time Display, Missing Historical Intraday Data, Chart Not Updating Your account has 6 days of usage time remaining. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-12 23:13:08
[2025-01-13 17:39:18] |
The "Emergency Account Activation" is meant for emergency purposes when you can not afford to pay for a renewal at that time. You should be adding funds to your account to allow for the automatic renewal to occur so you do not need to worry about this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
