Date/Time: Tue, 22 Apr 2025 14:20:40 +0000
Drawing Menu Window and Trade Menu
View Count: 196
[2025-01-11 20:28:54] |
nicktrader - Posts: 748 |
Vers.: 2732 Is there a way to switch off the Trade Menu if Drawing Menu Window is open? Many thanks |
[2025-01-11 20:47:28] |
Sierra_Chart Engineering - Posts: 19305 |
Did this exist previously? We can add an option to control this.
[2025-01-11 21:34:56] |
Only since a few versions. An option to control this would be desirable. Thank you very much. |
[2025-01-13 06:57:20] |
Check Global Settings >> Chart Trade Settings: Display Chart Trade Commands As Sub-Menu:Yes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-13 07:21:39] |
For “Chart Trading” you need a “No”, but then you have it also in the “Drawing Menu Window”. Unfortunately, you can't switch it off separately.
Date Time Of Last Edit: 2025-01-13 11:13:30
