Date/Time: Tue, 22 Apr 2025 10:17:23 +0000
Combining or adding charts from Thinkorswim to Sierra
View Count: 306
[2025-01-11 15:37:36] |
Gdiaz007 - Posts: 2 |
I have not been able to duplicate this function from TOS in SC. With TOS I can state SPY+DIA+IWM+QQQ in the symbol panel. What I get back is one single plot of the combined ETF's. So far I have been unable to replicate or mimic this in SC. I always get multiple plots. After using SC for about 2 months I am sure it can do this I just cant figure it out.
[2025-01-11 17:32:15] |
cmet - Posts: 690 |
What is the calculation of the single plot you're looking for? An average? Would help if you post an image of what you see in TOS including the scale. |
[2025-01-13 17:09:40] |
Refer to the following: Custom Calculated Symbols Or you can add multiple chart together by using any of the "Sum" studies. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-15 23:23:41] |
Sorry for the late response I got tied up with work. I am not sure but if you see the attached charts one is the stand alone ES. The other is TOS I entered /es+/nq+/ym+/rty. It appears to sum all four symbols, smooth them out and then plot 1 candle for that average/smoothing or whatever its doing to produce a single graph. You can do this with any TOS supported symbols, you can do sym+sym like the attached chart or sym-sym. Very flexible and vert accurate in term of showing marketing sentiment direction and trend. I am able do everything I do in TOS now in sierra and WAY MORE!!!. Just thought I would raise my hand on this one. Thanks in advance. Cant seem to find the correct chart combining feature.
[2025-01-16 15:28:31] |
The following does all of what you are wanting: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
