Date/Time: Tue, 22 Apr 2025 14:08:54 +0000
How to adjust delta bars proportions better?
View Count: 162
[2025-01-11 15:25:56]
gaoxxxx - Posts: 5
This is my delta bars, in which you can see a very high positive bar which made other bars not seeable anymore. what can I do to with it?
image屏幕截图 2025-01-11 231700.png / V - Attached On 2025-01-11 15:24:48 UTC - Size: 3.36 KB - 34 views
[2025-01-13 17:06:24]
John - SC Support - Posts: 39395
The only thing you can do is adjust your scale so you can view the other bars as you want them. Refer to the following:
Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale
