Date/Time: Fri, 20 Sep 2024 04:03:35 +0000
indicator of different bar period - 5-minute chart with 15 minute MACD
View Count: 1186
[2014-09-16 14:02:08] |
User27711 - Posts: 13 |
How can I have a 5-minute chart with 15 minute MACD? k.baek |
[2014-09-16 14:20:38] |
Sawtooth - Posts: 4091 |
You can put a MACD on a 15min chart then use the Study/Price Overlay on the 5 min chart. Or you could triple the Length settings of the MACD on the 5 min chart Date Time Of Last Edit: 2014-09-16 14:51:31
[2014-09-16 18:07:40] |
Refer to help topic 28 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
