Date/Time: Tue, 22 Apr 2025 13:45:20 +0000
preventing trading certain instrument/time
View Count: 244
[2025-01-10 20:17:44] |
qiw4u23oi4u234 - Posts: 34 |
I want to prohibit myself from trading certain time and certain instrument. Is there a way for me to do this? Also, I'd much prefer the global profit/loss management to work based on my closed PnL only. Is this possible? |
[2025-01-10 20:27:21] |
Sierra_Chart Engineering - Posts: 19305 |
No this is not supported: I want to prohibit myself from trading certain time and certain instrument.
The only thing you can do is set Order Quantity and Position limits. No definitely not: Also, I'd much prefer the global profit/loss management to work based on my closed PnL only. Is this possible? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-10 21:25:43] |
can i set different limits on full size (ie 0) and micro contracts? |
[2025-01-13 16:51:46] |
There is just the single limit set through "Use Global Trade Position Limit". Refer to the following: Global Symbol Settings: Use Global Trade Position Limit (Global Settings >> Symbol Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
