Date/Time: Tue, 22 Apr 2025 13:45:21 +0000
Session Times
View Count: 146
[2025-01-10 17:54:10] |
User116285 - Posts: 1 |
I want to ask for your Advice about session time. I've set brussels time, but time in Lithuania +1 hour, How to set proper session time and where can I do it? can you sent link with instruction? Everything works great, |
[2025-01-13 06:17:38] |
Sierra_Chart Engineering - Posts: 19305 |
Refer to: Time Zone Setting Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
