Date/Time: Fri, 20 Sep 2024 03:51:19 +0000
TT FIX connection
View Count: 928
[2014-09-16 13:04:31] |
batman_ - Posts: 190 |
Sir, If i connect TT FIX with sierra chart, can i still using the same ID to connect to XTrader trading platform simultaneously? Date Time Of Last Edit: 2014-09-16 13:05:53
[2014-09-16 16:27:06] |
We would expect this to work. However, we are not sure that the IDs would be the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
