Date/Time: Tue, 22 Apr 2025 14:41:14 +0000
[Programming Help] - Close event error. Windows error code 10053
View Count: 119
[2025-01-10 15:11:30] |
User303857 - Posts: 132 |
Hello Support. It seems like this disconnect happens every morning and takes several minutes to reconnect. Any idea if this can be resolved with my machine? Thanks ====================== |
[2025-01-10 16:38:33] |
Sierra_Chart Engineering - Posts: 19305 |
Refer to: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-10 16:38:50
